Easiest way to pull the engine in a C5?
Old Feb 22, 2005 | 10:08 PM
Miles in Florida's Avatar
Default Easiest way to pull the engine in a C5?
Top or bottom? I'm inclined to think top will be easier, since I don't have a lift.
One head's already off, so I figure I might as well take off the other, too. Then hook the chains to two of the head bolts situated diagonally from each other? I'll take out the steering rack, cause it's about 1" in front of the pulley.
Maybe this is a dumb question, but will there be enough room if I leave the stuff for ABS in there? I hear you can only bleed the ABS with a special GM tool, so I'd like to avoid it. Especially because if the brakes don't work until I bleed them, I'd need to have the car flat-bedded to the dealer to have them bled.
I coulda sworn I read a post about pulling the engine on an F-Body that said that you don't need to break the seal on the AC system, I can't believe that'd be true of a C5. I figure I'll take the rad and AC condensor out right away. Should I take the water pump and AC compressor off too, or leave them on until the engine's out of the car (wondering if the extra weight on the front might actually be helpful for the CG).
Anybody know of a write-up online? Any and all advice is welcome.
Thanks,
Miles
Old Feb 22, 2005 | 11:10 PM
Slowhawk's Avatar
LS1Tech Sponsor
The front frame will be in the way if you try to pull it out the top unless you pull back the whole rear/tranny assembly.I don't think I would even try to pull it without a lift.We just take the engine out the bottom with the subframe.
Old Feb 22, 2005 | 11:20 PM
MNC5's Avatar
I agree it needs to come out of the bottom
Old Feb 22, 2005 | 11:59 PM
2c5s's Avatar
Mine came out the top along with a few others I have seen.
Old Feb 23, 2005 | 12:12 AM
racecar's Avatar
Out the bottom, on a floor jack with a cradle that I made from steel flat bar.
I took the cup out of the floor jack and bolted the cradle in with one big bolt.
I put the car up high on some big jack stands. I unbolted the motor,
and used another jack to make the car do a wheelie and raise up about 6 inches, the motor slides right out.
Just mark the lines for the ABS and disconnect with a flare wrench.
You probably need to bleed some new fluid in there anyhow.
Go for it!!
Old Feb 23, 2005 | 03:29 AM
Blktie8's Avatar
Default Motor
Pulled it
20 hrs to pull and do engine mods and re-install
dealer gets 16 hrs
If you want to talk about it e-mail me back and I can send some pics
John
Old Feb 23, 2005 | 04:41 PM
ChucksZ06's Avatar
If you take it out the bottom are the wheels still on the car? I am thinking of out the top so I can move car while doing engine work. Suggestions appreciated.
Old Feb 23, 2005 | 07:22 PM
smask04C5's Avatar
out the top, less work
Old Feb 23, 2005 | 09:56 PM
racecar's Avatar
How do you get a hold of it to pull from the top? Where do you bolt on a chain or puller plate? The back of the heads are under the windshield!!
Old Feb 24, 2005 | 10:49 PM
That's where I was going with the question about leaving the water pump and AC compressor on, I was hoping somone'd say where they attached chains and what (if any) accessories they left on the motor, to put the center of gravity where it's best to have it.
You don't need to have your chains at the absolute front and back of the engine, they just need to be on opposite sides of the center of gravity. Load-levelers are only about $25 at Harbor Freight, and should make things a bit easier.
Thanks,
Miles
