Measuring Piston to bore clearance.
Where do you measure the piston? I seem to be way undersized at the top.
Is there a specific location on the piston that is speced by G.M. for measuring the piston diameter?
Sam.
From what I've seen people check at multiple locations.
I've actually never had to worry about it.
Loose never bothered me.
This depends on the alloys mix though. I am installing mahle forged pistons with a low expansion alloy and they only need 3 to 4 thousand clearance which is great cause you have a quiet piston when cold and the strength of a forging. Loose engines may make a little bit more power but ring wear will be severe with frequent rebuilds.
