forged aluminum
forged aluminum being new to me i'd like to know if they will take a beating
will they last in a 200 shot 7350rpm engine?
any input on forged aluminum would help guys
btw 7200 is the shift rpm but i hate loosing because of cutoff so ill set my cutoff to 7350
are you serious?
I would never venture into those rpms without at least ARP bolts on my rods and proper ring/pistons. And you also want to spray a 200 shot on top of that
True the crank and rods are tough for stock pieces but they are NOT unbreakable.
bolts: arp
pistons: mahle forged
heads: stage 2 garage made(yes valve seats were cut by a shop) mild overkill with upgraded valvetrain
cam: looking for something around 238/242 on 114lsa
boltons: full exhaust ls6 intake and mti airlid
trans and rearend:my current m6 with a moser 9 inch(i'm talking about my 99 z28)
n2o: can't afford nossle or nxl MPI going with power ring
and a good tune
btw i'm looking for flaws in my plan please find them guys
bolts: arp
heads: stage 2 garage made(yes valve seats were cut but a shop) mild overkill with upgraded valvetrain
trans and rearend:my current m6(its on my 99 z28) with a moser 9 inch
tune:by big G (true expert even does mafless)
ditch the stock rods and replace with either eagles (if you don't have money) or Lunati (if you do) and then you are good to go.....stock crank is fine....
Charlie
