Can an engine run without oil pressure?
I found it out when the lines to the STS turbo wasn't getting any oil. There should be tons of pressure where they tapped for the turbo's oil, but nothing comes out.
The guage is faulty too, cuz it keeps showing i have normal oil pressure, but lots of things point otherwise....
drive, or even starting the car with no oil preasure will tear stuff up. what did the shop say? Trending Topics
The guage...keeps showing i have normal oil pressure
The sts line is tapped at a location between the oil pump and the sending unit for the gauge.
If you are getting oil to the sending unit, but nothing out of the line, then the problem must be where they tapped that plate, or the line must be clogged.
It's unlikely that the gauge/sending unit suddenly quit working properly at the same time the STS was installed.
Although I drove my spun rod bearing home 50 miles knocking the whole way and it made it, the short block was trashed though.
