ls6 oil pump what oil Pressure
Old 03-04-2005, 02:20 PM
greentahoe's Avatar
On my stock pump with 80K on it I had 40 at idle with the new "LS6" pump I have about 50 at idle.
Old 03-06-2005, 06:39 PM
greatwhite99's Avatar
mystery solved... I changed the oil back to Mobile 1 and then filter to an AC Delco instead of the fram crap that was on there. I also found a leak under the filter on the pan. I guess I did not tighten it up enough after I dropped the pan for the Oil Pump.
Mike
Quick Reply: ls6 oil pump what oil Pressure
