Specifically main bearings. We had the machine shop we use set them at .0021 to .0025 in this motor we are doing. Is this where they should be? I just had someone tell me earlier this am, at another shop, that with an LS1 they have to be no more than .0019, preferably .0012-.0018 to make proper oil pressure. Personaly, I think the dude was full of ****, or just too picky, what's your opinions?
You'll be alright with those clearances, but you'll have lower oil pressure.
I have .015-.020" on my mains, a a little bigger spread (up to .025+") on my rod bearings due to some liberal polishing.
Either way you'll be fine, just don't be surprised if the oil pressure is lower.
Ben
The clearance is always personal preference. On a aluminum block we currently shoot for .0011-.0016. On a iron block below 1000hp we shoot for .0021-.0025. On a drag engine above 1000hp we would start to loosen the clearance up as high as .003.
Thats cool, sounds like we'll be ok either way, but from now on I will specify to my machine shop no more than .002. Thank you for the info. As always LS1tech.
I have .0025 on rods and main and cary 52 cold and 40 hot on oil pressure.
I would be happy with that. We have an iron block 370 that only does 40 cold and 25 hot idle. But it maintains 40+ at cruise and 55-60 at WOT. Ive heard 10 psi/1000 rpm and your ok.
On a side note, where did you pick up those Motron 60# ?
The mains are run tighter ( in general) on aluminum blocks because the aluminum expands more than an iron block. I am putting together a 403 aluminum with about 1.6 clearance and the crank spins very easily.
