How much lift?
Old Mar 4, 2005 | 10:07 AM
DragLS1's Avatar
Question How much lift?
How much lift can a stock shortblock 346 handle without clearance problems?
Does the 71cc LQ4 or LQ9 head give you any more clearance?
Old Mar 4, 2005 | 10:11 AM
Race Car Driver's Avatar
11 & 7 Second Clubs
While John was alive, LPE wouldn't sell anything over .550 w/o valve relief and they may still adhere to this view. More aggressive builders go to .600. There is no absolute here.
Old Mar 4, 2005 | 10:19 AM
technical's Avatar
Depends on the duration more than the lift.
Old Mar 4, 2005 | 10:23 AM
DragLS1's Avatar
The duration is 242, 248 @.050 lobe sep at 114....
Old Mar 4, 2005 | 10:25 AM
DragLS1's Avatar
It looks like I will probably have to flycut...the lobes that comp and I specced go to around .655" with the aforementioned 242,248 degrees @.050. This is a turbo motor.
Old Mar 4, 2005 | 10:42 AM
technical's Avatar
You're asking if a 242/248@.050 .655 cam in a stock motor needs flycut pistons?
The answer is
Now when you say turbo motor, are you putting dished pistons in there?
Old Mar 4, 2005 | 10:45 AM
DragLS1's Avatar
Yeah....dumb question.....thanks guys
Old Mar 4, 2005 | 10:48 AM
DragLS1's Avatar
The pistons for now are stock...I will be using the lq9 heads with .074 gaskets from cometic and using race gas for anyhing over 10 or 12 psi. I think the hyper pistons will hold until I put diamond dishes in it.
