compression 383 help
Old Mar 4, 2005 | 03:33 PM
camaroz28nbm383's Avatar
Default compression 383 help
since i am going to be pulling the heads off to cheak the block for cracks i need to know how to get more compression out of my 383 3.905 bore 4.0 stroke it has mms stage 2 heads milled .030 with the stock 98 head gasket .040 i think the cr ratio is about 10.5 i think i need to get to 11.0 i need to know how to do this because i dont know if you can mill the heads more or run a thinner head gasket?
Old Mar 4, 2005 | 03:39 PM
jrp's Avatar
jrp
SN95 Director
what casting heads are these, your not 10.5 unless you failed to mention you have dished pistons.
going by what you'v given and assuming a 806 castings milled .030, 3.905 bore, 4.00 stroke, .040 gasket, 3.910 gasket bore, -.008 deck height i get 12.05 CR
Old Mar 4, 2005 | 04:07 PM
sorry they are ross dished -9 with 806 casting
Old Mar 4, 2005 | 04:48 PM
Boostaholic's Avatar
You can always mill the heads.
Old Mar 4, 2005 | 05:07 PM
jrp's Avatar
jrp
SN95 Director
can mill the heads .010 and run a .030 gasket or mill the heads .020.
but i'd just start off with a new casting, 5.3 you'll have the smaller chamber to start off with.
Old Mar 5, 2005 | 09:26 AM
They are milled .030 allready so i could go .010 more what would that give me for cr?
Old Mar 5, 2005 | 10:53 AM
Wades SnS's Avatar
Default cr
the stock 98 gasket is carbon composite it has a 4.135 bore and a .053 thickness
Old Mar 5, 2005 | 07:01 PM
jbuckweiser's Avatar
have you gone to www.smokemup.com? All the math calculations are there.
Old Mar 7, 2005 | 02:57 AM
wallstAL's Avatar
http://www.rbracing-rsr.com/compstaticcalc.html
Old Mar 7, 2005 | 07:13 AM
SAM98WS6's Avatar
http://camaroz28.com/services/calcs/
Mine is 11.7:1 with 65cc heads, .042 Cometic, +.007, -2cc, 6.125x4.00 and I run 92 octane no problem.
