timing chain problem
Old Mar 5, 2005 | 09:44 AM
FBodyRider9902's Avatar
Default timing chain problem
a new challenge in this cam install is the timing chain. The lower smaller crankshaft spocket on my 99 camaro is pressed on tight, how would i go about removing that spocket(gear) in order to install my new double roller? Also how do i go about installing the new Dual gear, is there a special tool that i don't have? anyone who has done one of these please help me out
Old Mar 5, 2005 | 10:34 AM
P Mack's Avatar
Just rent a small puller from autozone to get the gear off. To get the new one on, slide it on the crankshaft and use the old one and a rubber mallet to hammer the new one on.
Old Mar 5, 2005 | 10:51 AM
1FASTLS's Avatar
Like P mack said go to autozone and rent or borrow a puller, they also have them cheap to buy also, When I installed one for my budy I cut a piece of pipe that would fit over the crank and was a couple of inches longer and used my harmonic balancer installer to press it on worked great. Make sure its small enough that your not on the teeth.
Old Mar 5, 2005 | 10:59 AM
Default thanks
hey thanks a lot guys for all the tips and details
