AFR 205 Cam Decision
http://forums.corvetteforum.com/show...6&page=1&pp=20
https://ls1tech.com/forums/dynamometer-results-comparisons/284331-afr-205-232-236-results-2000-c5-a4.html
What would you select, and why? What stall also? Thanks!!!
Mill the head to 59 cc
Run an .040 gasket for better quench
THEN slide the 232/236 in.
That would be a stout combination.
Without the CR increase and the better quench it would make decent peak #'s and probably just OK "average" TQ and HP figures. A slightly smaller cam with higher CR and better quench might get you down the 1320 quicker and faster, not to mention be a better combination for cruising around town.
Tony M.
PS Without notching, even getting the 232 in (by not milling the heads) might pose a potential problem in the future due to minimal P to V....One missed shift or a mishap in the water box and you will have a couple of bent valves or worse. Just something else to consider in your decision making process.
QUOTE]
Just depending, that should yield you a compression ratio of approx. 11:3 or 4.1. You might also need to upgrade your fuel injectors.
if you have an angle drill it will be especially easy for the back ones (might be the only way possible)
i would want a freakin LOG of a camshaft if i was spending the money on AFR's and a 90/90 combo
From what we've read and Tony has posted, you don't need a log with these heads.
Mine is a 227/231, should be interesting!!
Just to clarify.
Due the the extremely efficient nature of the AFR heads (stong low/midlift flow....good peak #'s and small cross-section) you don't need a big cam to put up big numbers. BUT....that doesn't mean that a bigger cam (with the right set-up, compression bump. etc.) won't make more....it certainly will.
But whats most important is getting the combination right....I'm all about putting in a sizable cam for your weekend warrior if you don't have a problem with a lopey idle and the lack of power typically seen at cruising speeds....BUT, to do it right you have to notch the pistons to be able to mill the heads to get the static CR up....its VERY important on the larger cam stuff or your dynamic and static compression is too low. You have to bump the CR to help build cylinder pressure lost in the overlap cycle from the larger cam install.
I believe there is a post in this very section concerning those issues with low cranking compression etc.
Tony M.
NEED to know.. Thanks!
....although it does suck pulling a tractor trailer around all the time
this illustrates the point that i was making, along with what many others try and make.
it IS all about what you want, i'm going for the big cam only approach right now. maby NEXT summer i'll swap heads around and see how she goes,maby i'll be co-op'ing at a plant somewhere in the future and have a little change in my pocket
Guys...Always check P to V even if you are putting in a small cam and think you have a "country mile". Checking would haved saved a few peoples butts on this very forum that didn't because they read (or their buddies told them) they should be "OK".
Tony M.
Tony M.
I was going to anyway, but was just worring it was a definate notching situation. I know nothing is ever 100% but didn't want a "Well with that cam you have too"
Thanks for the help.
