ticking, good or bad?
Old Mar 5, 2005 | 10:20 PM
2000ramairTA's Avatar
Default ticking, good or bad?
my cousin has a 1998 t/a and i have a 2000 t/a they both have under 35,000 ,miles. When you first start it up and a for a bout five - seven minutes after startup the valves tick kinda loud. Is this normal operation?
Old Mar 5, 2005 | 10:25 PM
Grimes's Avatar
That sounds very normal. My 02 Z28 sounds like a diesel for the first few minutes, then after driving around a while, it becomes very quiet.
Danny2tek's Avatar
The infamous piston slap.
Old Mar 5, 2005 | 10:29 PM
itchygomey98's Avatar
I wouldn't call it normal, but GM does.
Old Mar 5, 2005 | 10:39 PM
SmaknaSS's Avatar
That was so annoying, That is exacly what both my cars did when they were stock, When I did my H/C swap I changed out the stock lifters with comp 850-16's. Now my valve train has a sewing machine sound but I dont have that annoying ticking sound any more. In my opinion It's alot quieter now.
Old Mar 5, 2005 | 11:51 PM
LS1s R US's Avatar
Yeah I believe they all do it I just live with mine some of the newer models had a tsb on replacing the oil pump oring because they leak and airiation of the oil makes it tap.Some fix it and some don't.My freind has an 01 and he swapped out using the longer oil filter and his queitened down a lot?
