what else is needed?
921 comp cam spring kit
do i need a new timing chain (what is the benefit or reason if i do)
and what about hardend push rods?
and the yank 3600e should be in soon also.
im about to order the "Thunder Racing Custom Camshaft - 230/236 .590/.598 112 LSA 2400-6800 RPM Power Band. Excellent mid-range & high RPM power. 3200+ stall, 3.42+ gear, computer tuning required. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended"
is there any thing else im missing?
Tyler
Don't forget to get a tranny cooler with your stall. Very important if you want your transmission to last.
Good luck, it sounds like your gonna have a beast on your hands soon.
Lou
