Crane Dual Springs? GOOD?
Old Mar 10, 2005 | 07:38 PM
CraZee ZO6's Avatar
Default Crane Dual Springs? GOOD?
How are the Crane Dual Springs?
My tuner installer wants to use these. Are they one of the best? How often would springs have to be changed for maintenence?
Thanks
-Zee
Old Mar 10, 2005 | 07:40 PM
jrp's Avatar
jrp
SN95 Director
with what cam?
Old Mar 10, 2005 | 07:48 PM
CraZee ZO6's Avatar
Originally Posted by jrp
with what cam?
TTP V3 Equalizer cam.
Old Mar 10, 2005 | 08:15 PM
calongo_SS's Avatar
There are better dual springs IMO (patriot or PRC). But if TTP wants to use them on there cam (I'm assuming they are installing) then maybe they have some reason. Spring life will depend on the cam (lift, ramp rates etc..). If I remember correctly that cam is pretty large. You'll probably be checking spring pressures at 15 - 20k.
Old Mar 10, 2005 | 08:22 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Crane 893 springs?
Old Mar 10, 2005 | 08:28 PM
smask04C5's Avatar
crane 144832 with ti retainers are fine
Old Mar 10, 2005 | 08:50 PM
Slowhawk's Avatar
LS1Tech Sponsor
918's won't work with that Cam.Use what TTP suggests
Old Mar 10, 2005 | 09:34 PM
SMOKIN01TA's Avatar
im running cranes, i beat the **** out of them and great luck so far
Old Mar 10, 2005 | 10:34 PM
CraZee ZO6's Avatar
TTP suggested crane DUALS.. is that 918s?
I AM going with what they recommended, I just wanted to know how they were.
Old Mar 10, 2005 | 10:38 PM
01_SuperSlow's Avatar
The crane duals (832's), are really good springs.
You will most likely have to shim them though.
Tiger2o69's Avatar
918s are comp cams single springs...
Old Mar 10, 2005 | 11:20 PM
CraZee ZO6's Avatar
Thanks! Yeah TTP is doing the install and tune. Hoping for 440+rwhp on motor and some BIG numbers on spray, 100 shot tnt wet.
-Zee
