For those thinking about the fm13 cam
This cam pulls through the entire rpm range , not just topend like a lot of the lower tq cams out there right now. Very streetable, sounds real nice but not real radical. Now any one thinking of this cam , you cant go wrong,.
South Florida, These heads were ported with tq in mind by an old school head porter. He did not open the runners at all, just bowl work and went with 2.02 valves with a good valve job. The flow numbers at peak are not that great but the down low and mid lift numbers are close to all the sponsors heads. The exh. flow on par with most of the sponsors heads. I would love to see this setup in a light car but not going to gut my car. The only weight reduction I have done is AIR delete, and front sway bar off. other then the spare tire at the track it is completely like it came from the factory with every option still in tackt
I do have mild ported heads, a little smoothing in the bowls and 2.02 valves on the intake and stock exh valves. the exhaust do good though. the heads flow 256 @ .500and 257@ .600 on the intake. 219cfm at .600 on the exh. heads were shaved .015 for around 10.5/1 compression
Allan looked at my graph and said that the heads did not heop much over stock but they did not hurt either. I think they did help with the track times she runs though.
Nice #'s. What head gasket are you running? GM MLS? Did he open the exhaust ports at all or just clean them up? Thanks.
OH
well then what about the f14?
or.. is there an f15?
got to match this 4000 stall for my daily driver
BTW, specs on the F13 are 230/232 .595/.585 112/114+2/4
