Car not idling
Old Mar 12, 2005 | 01:37 PM
Iron Sights's Avatar
Default Car not idling
Ok first off my car is as stock as I bought it (the only mods that I can find on the car is a catback...which with my luck is a flowmaster ) I haven't done any cam swaps or anything that should affect the idle. Today I took the SAT and when I started the car to go home it died instantly...after this happening again I gave it some gas to keep it going but I noticed that the rpms fluctuated from as high as 1000RPM to 500RPM. For the first 4 miles of my drive home the car would die anytime I pushed the clutch in long enough for the engine to idle down. It finally quit doing this but I noticed the engine idle down a lot faster than normal when I would coast; so I know that the problem didn't go away. The car only has about 17,400 miles (bought it with about 10000) and it just got out of the stealership last monday for a looking seal on the rearend. Any ideas about what could be going wrong?
*edit* Its a 2002 Z28 M6 *edit*
Old Mar 12, 2005 | 07:05 PM
Lvmyz28's Avatar
sounds like you somehow got a massive intake leak, or your IAC valve crapped out!
Old Mar 12, 2005 | 11:01 PM
Cody Brooks's Avatar
clean your iac valve make sure its not sticking and check for vacuum leaks. I had some idle trouble recently due to lots of stuff on my iac valve. cleaned it off and it idles smooth now.
Old Mar 13, 2005 | 03:06 AM
TNormZ28's Avatar
Bad MAF? Or, try checking and make sure nothing crazy is going on between the MAF and the TB, gaps that might be sucking in un-metered air.
Old Mar 13, 2005 | 03:24 AM
2MuchRiceMakesMeSick's Avatar
I had a simalar issue a while back. Check for an intake leak. If you have hptuners or similar check for misfires.
Old Mar 13, 2005 | 09:43 AM
Well it went away...it started doing this when my car was on about 1/4 tank left. I'm attributing it to water in gas for now, if it happens again I'll know what to check for. Thanks.
Old Mar 14, 2005 | 01:43 AM
LFNDUST's Avatar
sounds like alternator to me...haha by the way he is explaining it but its probably MAF or IAC...my $0.02...
Old Mar 14, 2005 | 10:16 AM
Bull_in_a_china_shop's Avatar
clean the 2 brass ground posts on either shock tower front./ Take ground wires off and really sand/clean them good. Those bein corroded used to make my idle go NUTS! just one of the fabulous gotchas of cpmputer based cars.
CLEAN EM! :-D
By Brett Foote | 2026-06-04 05:00:17
