Help needed ASAP *cam swap*
Yah, I just NAILED my right middle finger knuckle on something in the engine. Cause a nice cut and more blood than I thought a knuckle had ![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Update:
Valve covers are now off. As well as the rocker arms and pushrods
Update:
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Your knuckes will love you when it comes to the valvesprings...if you're using a 2 arm compressor like I did...
ps. you might as well get rid of that fxx cam and go with something bigger now because in 6 months you will want something else and then will have to go through all this again. lol....!!
That's what she said...
tip # 5000 - dont use 12 point sockets unless you absolutly HAVE TO ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
do not tighten the valvecover bolts to 15 ft/lbs or they WILL break off in the head![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
if you have a 99+ year model, remove the last coilpack rail bolt on the passenger side and throw that bitch away.
once the radiator is out, you can remove the petcock no sweat.
have a torch ready for the pulley, and put it in the oven before re-installing.
Originally Posted by LSONE
once you get to the oil tube, please stick a wash cloth or something in the oil pan to catch the nut when (not if, trust me) it falls. would have saved me ~5 hours
Originally Posted by DanZ28
Agree'd!
Little trick I do is put some safety wire on the bolt after I undo it a few threads, wrap it around and twist it like a bag tie. It won't fall in the oil pan I guarantee you...I still put a rag in there anyway though![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Dan
Dan
Originally Posted by 1984camaroz28
why are u taking the coil packs off just un hook them from the harnesss and unbolt the vavle cover......
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
