Cam question
Old Mar 13, 2005 | 10:14 AM
bobby1's Avatar
Default Cam question
I have a 2000 ta m6 just bought pacesetter headers and hooker y pipe and my question about the cam I bought it was comp custom ground 232-240 595-605 with 110 lsa I was curious if anyones running this size cam with stock heads. Was just wondering if I would any piston to valve clearance issues with cam. Many users on this site run the t-rex so I was thinking that it should fit because the t-rex is 238-242 608-612 110 lsa, Is this true? The power band is 2500-7200 it starts making power sooner!
Old Mar 13, 2005 | 10:19 AM
PREDATOR-Z's Avatar
dial indicator
soft spring
modified lifter (to take away hydraulics)
Then find your PTV clearance.
Old Mar 13, 2005 | 10:27 AM
bobby1's Avatar
Because the t rex is bigger wouldn't my cam fit easier because its smaller!Thanks for any input its much appreciated>
Old Mar 13, 2005 | 11:01 AM
PREDATOR-Z's Avatar
.050 specs cannot determine PTV clearances.
The VE's will be different.
Perhaps someone using this cam on stock heads can tell you for sure.
Old Mar 13, 2005 | 12:28 PM
bobby1's Avatar
thanks for the imput.
Old Mar 13, 2005 | 02:51 PM
rally2247's Avatar
WOW!! That cam is pretty heavy. Is this your daily driver, because that idle might be a pretty rough.
Old Mar 13, 2005 | 04:03 PM
bobby1's Avatar
It is my daily driver but I was looking for the most aggressive cam I could put in my car and not start making power at 3500 like the t rex and I was looking at more top end than the magic stick. Basically I'm looking for a ***** to the wall cam that would fit under stock heads for now until I get some afr heads!
Old Mar 13, 2005 | 04:29 PM
rally2247's Avatar
I see....
post your gains and opinion after you install it.
Old Mar 18, 2005 | 07:58 PM
bobby1's Avatar
Angry
I see....
I got 349 rear wheel horsepower on a dynomometer which is load bearing dyno instead most of the typical dynos most people use but the car runs fine considering its not tuned. I know for fact it would make a lot more power on a regular dyno. Two years ago I made 335 rear wheel with only hypertech mti lid and borla exhaust and thermostat
