Dowel Rods?
Old Mar 15, 2005 | 05:59 PM
DJB's Avatar
DJB
12 Second club
Default Dowel Rods?
Where can I buy the 5/16 rods to hold the lifters up? How do I need to modify them to make them work?
Old Mar 15, 2005 | 06:00 PM
Red99TA's Avatar
Any hardware store should have them (the wooden ones). I sanded down the side of the one that I used on the driver's side so that it was flat instead of completely round. Just used a file to do this since the wood is so soft to begin with.
Old Mar 15, 2005 | 06:20 PM
TARyan21's Avatar
I bought mine at a steel shop. You should have on near you, one that specializes in bolts and stuff. Make sure that they are longer than your cam!!!
About 2 feet. I used a grinder and I made both of mine flat on one side because I had trouble getting them in either side. After they were grinded, like cake!!! Also make sure that you don't bump on out ANY while taking the cam out. Hope this helps.
Old Mar 15, 2005 | 06:22 PM
P Mack's Avatar
I used 5/16 for the drivers side but couldn't fit it in the passenger side. For the passenger side i used 3/16 wrapped in velcro.
Old Mar 15, 2005 | 06:42 PM
DJB's Avatar
DJB
12 Second club
Thanks guys I will try to find some tomorrow.
Old Mar 15, 2005 | 09:03 PM
Cstick's Avatar
Just go get 5/16 brake line from an auto parts store. Then put it in a vice and oval it, make a point at one end and a handle on the other.
Old Mar 16, 2005 | 12:39 AM
Boostaholic's Avatar
I did the same thing, my rods were a bit too big so I sanded them down. Worked perfect.
Old Mar 16, 2005 | 12:57 AM
TheBlurLS1's Avatar
That's what she said...
lots of people like to round the ends a bit for a smoother entry as well, and if you're using metal, lube that baby up
YIKES what a post
