Picture of correctly installed rear crank seal?
Does anyone have a picture handy of what the rear main crank seal (installs into the rear cover) should look like?
Thanks
Ben
Thanks
Ben
Up.....
When you install this- it is generally done with the cover still bolted in place?
I don't have the GM install tool, but I read that the seal can be driven into place (after it is correctly seated on the crank) with an appropriately sized piece of PVC pipe?
Thanks
Ben
Thanks
Ben
Thanks
Ben
Thanks
Ben
I don't have a picture. But the key (as I understand it) on this seal is it is double side lipped and you have to make sure that neither lip folds in and lays correctly. Of course, I am not sure how you can check on the inside side of the lip. Yes, the cover is in place and aligned before you install the seal. The thought of having a leak after I got the engine together prompted me to pay the bucks ($150?) for the Kentmoore tool. Wheel 2 Wheel would sell you theirs tool for about $90.
