What heads with TSP MS3 Cam?
What heads if any will work with the MS3 cam without flycutting the pistons? I'm considering some heads later on down the road. Let me know if there is anything out there that will work. Thanks
Steve
Steve
LSxGuy widda 9sec Mustang
A little more expensive than most but the AFR's 205's will clear without flycutting and you can run a .040" Cometic MLS gasket also. I've installed and checked clearance on this setup already.
We're also working on a smaller valved PRC head to test out with the MS3 camshaft and should have some clearance numbers in about 2-3 weeks. Hopefully we'll have enough clearance as there are a few ppl with the MS3 that are ready for heads now.
