Moble 1 - 15K mile oil
Originally Posted by stang killer
i hardly get 6k miles on my car in a year, lol. Let alone 15. But a problem that youd run into with the LS1 is, at 15k miles, there would be no oil left in the pan with the way these motors go through the stuff. Hell I find about 6oz of oil in my catch can every 3k miles, and im sure its not catching it all either. That would be my main concern.
I guess I am lucky then - went around 8k miles and burned less than a 1/4 quart of mobil 1 10w30!
Just cause it says its good for 15K dosnt necessarily mean thats what you should use it for. Once some oil analysis results start coming back, we'll all have a better idea of what this oil can and can not do.
BTW, the 5K stuff is conventional, the 7.5K is a blend, and the 15K is full synth.
Originally Posted by 01SSRMS
Hey Tranzor,
Hasn't Amsoil been doing similar stuff for years. High mileage oil with a good filter that you change between oil changes?
The oil filters they use have a large filtering media, so they trap quite a bit of dirt... their filters are rated as 12.5k mile/6 month interval filters. But I would always change the filter whenever changing the oil... so with mine, I change my oil and the filter every 6 months. I use Amsoil XL 10w30 (5w30 in the winter) and an Amsoil SDF32 filter.
If you were using the Series 2000 0w30, I'd go with 1 year intervals (I doubt any of us drive 35k miles in less than a year's time) and change the oil filter at that time, unless you go over 12k miles before a year is up.
Originally Posted by Tranzor_Z28
I'm lucky if I get to 6k in a year, so I know what you mean. I have 24k miles on my 2001 Z28 I bought new in 2001... so that's right around 6k a year. And that's counting the first couple of years when it was my daily driver. Now I'm putting less than 5k miles a year on it and it only comes out of the garage on sunny days.
Originally Posted by mmmchickenboy
I put more than 6k miles on my T/A over the last two months!
