New rollmaster timing chain is loose
Old Mar 26, 2005 | 10:24 PM
98TXFBODY's Avatar
From: Used to live in South Texas, Now in North Carolina
Default New rollmaster timing chain is loose
I have a Rollmaster double chain. (its not the one with the bearing) anyway...first the cam sproket wouldn't fit onto the cam. I took a dremel and ground it pretty good and if fit on the cam. then when I got it all bolted up the damn chain it loose. I have put 3 or 4 of these on before and they were all pretty damn tight. My stock chain in my old motor had 50k on it and it was not half as bad as this one.
Anyone have any ideas? Its a 04 cast iron block.
Old Mar 27, 2005 | 11:18 AM
P Mack's Avatar
I would send it back. Mine was tight as hell. If it's as loose as you say you'll probably jump a tooth.
Old Mar 28, 2005 | 11:29 AM
98TXFBODY's Avatar
im sure it would.....it will get even worste when it streches a little bit. I ordered a new one already....hope i works
Old Mar 28, 2005 | 11:41 AM
madpwr1's Avatar
this might be on same topic ... anyone use GM Timing Chain dampner? suppose to reduce chain slap keeping it tighter for engines operating above 6500 RPM.
