383 stroker....
Old Mar 29, 2005 | 03:30 PM
ArcticZ28's Avatar
Yep, that was me I know I won't be coming close to its FULL potential as a 383, but I would hope that in using the 383 I could get a good amount more ponies than just putting this motor back to stock (for only a little more money while the motor's already out). What kind of numbers do you think I'll make?
Old Mar 30, 2005 | 04:02 PM
v DaN 02's Avatar
Originally Posted by jrp
thats for a fully machined 402 shortblock. SDPC and SLP 402 shortblocks can be had for ~4k; thats block, eagle rotating assembly (4" forged crank, 6.125 forged rods), off the shelf pistons (diamond flat top or dish), and bearings. block machined and ready to go with everything already assembled.
like i said, the price difference is minimal.
where can i get this motor at? got any links for me to look at so i can see if i can get any better deals? does the stock wiring harness work with this motor? is it just like bolt, plug and play? will it use the stock motor mounts?
thanks for the info... Dan
Old Mar 30, 2005 | 04:21 PM
DrkPhx's Avatar
Check the thread in the LS2 forum; it has all of the details. The SDPC is a killer deal and comes with some LS2 parts that are required, but you will need the LS2 lifter retainer trays.
Old Apr 1, 2005 | 01:28 PM
v DaN 02's Avatar
couldnt find exactly what i was lookin for? anyone have a link? to a distributor? or a website?
thanks in advance....
Dan
Old Apr 1, 2005 | 02:11 PM
DrkPhx's Avatar
Dan
2nd thread from the top.
https://ls1tech.com/forums/generation-iv-internal-engine/243997-ls2-402-short-block-sdpc.html
