Hand finishing help
Hand finishing help
I am at a delima. I own a repair shop in Ft. Lauderdale (free labor) and for Christmas my girl got me the Patriot LS6 stage 2 heads with 2.05/ 1.57 59cc chambers and I was floored! I put them right on and now realize that with a little valve job work and hand finishing they flow quite a bit more! Do you seasoned guys feel that it would be worth the labor and cost (gaskets and bolts) to pull em and put some time in em?? The labor is free but worth it? The car is in the 11's for sure, pulls like crazy but you know how you get when you second guess yourself, I'm about to start loosing sleep!! Thanks for YOUR thoughts. They could go from 304cfm to 320ish I'm told, and the mid lifts might be able to snap a neck a little harder!! Do you guys know Patriot sells head bolts and gaskets for $85!! Pretty cheap!
