Fuel issues
Old Mar 30, 2005 | 05:46 PM
Blue Falcon's Avatar
Default Fuel issues
My car is misfiring and actually threw a P0366 (crankshaft position sensor) code because it misfired so much. The car would actually die and I couldn't start it for approx. 10 mins. It generally happens between 2-2500 RPM's. It normally happens at low to mid throttle. When the car is misfiring the 02 millivolts were around 90. It seems like the car just isn't getting enough fuel at that point. I did just change injectors with the Heads/cam install. I adjusted my IFR by the correct amount. Also this problem has just started a couple of days ago, and I have had all of this done for a month or so
Old Mar 31, 2005 | 04:42 PM
anybody???
Old Mar 31, 2005 | 05:22 PM
Tech's Avatar
Put some stock injectors on it and see if your problem goes away.
Old Apr 1, 2005 | 10:41 PM
Cerwin Vega Fan's Avatar
Does the car always sseme to be starving for fuel? Maybe a clogged filter or a weak pump could be your problem.
Old Apr 22, 2005 | 05:30 PM
stock injectors are back in, and its still starving. Car is acting alot better now that I have used a Tech II to do a Crankposition Relearn, but it is still stalling out. The car does at least idle now, unlike before
