engine knocking
Old Apr 5, 2005 | 12:16 AM
ruck98's Avatar
Default engine knocking
my engine was knocking so parked the car i checked the oil and it was a half quart low and i just changed the oil in the week before i looked at the oil pressure gauge and it was reading zero i am going to buy a oil pump do think that will fix the problem.
Old Apr 5, 2005 | 12:20 AM
Droptopws6's Avatar
Half a qt low wont result in a knock , good luck.
Old Apr 5, 2005 | 02:12 AM
TheBlurLS1's Avatar
That's what she said...
zero oil pressure is not good my friend, i hope you arent driving the car while this is going down.
sounds like you may have bearing problems as well
Old Apr 5, 2005 | 02:21 AM
Wicked_Hugger99's Avatar
also might have bad Knock sensors...the ones on my 99Z went out causing the KR to spike everytime it shifted
Old Apr 5, 2005 | 02:28 AM
TheBlurLS1's Avatar
no i think he means an actual KNOCKING NOISE, not just the knock sensors causing knock retard
or do you mean the timing is so far retarded that its causing knocking noise?
