Front Valve cover breather started smoking / loud tapping sound also
Yesterday, I was driving home from work and noticed the car was "chugging" when accelerating (not at WOT), I pulling in the garage and could hear an EXTREMLY loud tapping sound. I know my valvetrain makes alot of noise with my setup, but this was noticably louder. Also, I have front and rear valve cover breathers and the front breather was smoking. I grabbed a towel and pulled it off and the towel was marked with oil - so oil is coming through the breather. Is this normal? Do they need to be cleaned - if so, how? I only have ~500 miles on my new setup and ~10 WOT runs on it. I am taking it easy until I felt it was broken in.
This morning, I went to start it and it was idling like $hit, so I backed it back into the garage and took the winter beater
what 'cha think?
what 'cha think?
Sounds to me like something in the valvetrain let go. The "chugging" may be a missing cylinder. Any codes?
I think I'd get out my stethoscope and isolate the source of the noise. Assuming it's coming from one of the heads, I'd pull the valve cover and have a look.
well, this morning I started her up to listen closely for a broken spring, but the loud ticking sounds does NOT seem to be coming from the engine, rather under the car or exhaust (sorta like tick-puff-tick-puff real quick) and when I started it I had alittle black smoke.
Drove around for a few mins and got this code:
P1153: Heated Oxygen Sensor (HO2S) insufficient switching bank 2 sensor 1
Still idles like crap and get a chugging feeling when starting to accelerate. No WOT runs.
So, I am thinking exhaust leak. My exhaust BANGS hardcore - plan on addressing that today/this weekend also. Got called into work today so I will a-tap this afternoon and check for obvious exhaust leaks
