Pistons: Reverse Dome vs Flattop with dish
Also, how much dish is considered a lot for a FI piston, anything over -10cc?
Phillip
From one standpoint I think it's just semantics. A Reverse dome is used to mirror the combustion chamber to get the best burn possible for a compression ratio. Usually a reverse dome is there for low compression race engines, like a 9:1 NASCAR engine or a blown engine.
I would rather have a large dish in the piston and a small chamber to get the compression ratio I wanted rather than a big chamber. It does add weight to the piston, and makes you run a shorter rod sometimes, but it works better for burn.
That's my thoughts.
Bret
