All Ignorant People
I would get a pushrod length checker to check your true length...
I thought the radius of the base circle was .776" or 19mm on stock ls1 cams for 02...and you said yours measured???1.265 where did you get this #??? is this a rocker ratio math thing??? that would put you at .744 which is .032 smaller.... meaning you need a 7.4 pushrod for your setup
get a puhrod length checker...and find out for sure....
try one of these
http://www.jegs.com/cgi-bin/ncommerc...81&prmenbr=361
or just about anybody's length checker for that matter...
use it to check with your current rockers/cam/heads setup
then check preload....
http://www.cranecams.com/?show=hydraulicLifters
about half way down is a pretty good way to check preload on hydraulic lifters(like our ls1/ls6 engines)
if you have a pretty health cam lift and duration...you will always have some noise from the valves reseating afeter such a large lift.....
you have to have some pressure at start or it would travel till it has enough pressure to do its job...too much preload and it binds...not enough and it has slop before actually pushing up on the the pushrod...same deal as with installed heigth on valve springs.
My engine makes very minor sewing machine noise. I believe the more radical the cam the louder the noise will be. Example: Faster ramp, higher lift cams, larger than mine in signature below.
Factory OEM uses much slower ramp speeds.
.006 271*
.050 221*
.200 135*
and comp cams 918 valvsprings.
.006 271*
.050 221*
.200 135*
This forum is made up of enthusiasts, some with lots of experience, some with less and some with none - that goes for the sponsors too - some are more retailers and others have lots of experience and talent.
Dealing with the LS1 and it nuances is not always easy and in some cases requires a good deal of research, analysis, trial and error, etc. which very few of the enthusiasts have the time for and the same goes for the sponsors - even the talented, knowledgeable and caring ones.
None of that however makes them or us ignorant, it just means most of us haven't figured this problem out yet.
i think someone correct me if iam wrong plz This forum is made up of enthusiasts, some with lots of experience, some with less and some with none - that goes for the sponsors too - some are more retailers and others have lots of experience and talent.
i think someone correct me if iam wrong plzor a few more dollars and get it real close with 7.425 (only off by .005)
If you spend way too much money you can get custom length 7.430 pushrods..." So it will help, but you still need to do some set up work.
I'm with DaddySS, pretty hard to get excited about helping someone that starts with an insult.
get over it...you're in here posting and reading too....
and I said that in post #4...which I started typing before post #2 and post #3 were even there....and I also stated that he should measure to find out for sure....
if you are not going to help...then get lost...and quit bitching.
now back on topic....
really the noise comes from valvetrain geometry mismatch....
we definately need to fix your geometry and put in the proper length pushrods first...(buy a checker like I talked about above) after that then it becomes important to get the proper preload..... try setting them for around .080 preload(factory ls1 preload spec??? ish???)....and then get the engine warm....stop it and check where you are at.... being that it is IRON it will not change a whole lot.... after is it hot...
what I dont know is what the hydraulic lifters preload should be for an Iron engine.... but we could do the same math for it too once we find out for sure...
and I guess we could try to find out what the stock hot ls1 preload actually is...and set it for that...that would most likely yield the best "quiet" results
my guess is that it is supposed to be around .030-.060 hot
the threads are M8 x 1.25
and count your turns.....
.080 [in->mm]
2.032mm (preload of .080 = approx 1 & 5/8 turns)
.030 [in->mm]
0.762mm (preload of .030 = 219* = just under 5/8 of a turn
.060 [in->mm]
1.524mm (preload of .060 = 439* = almost 1 & 1/4 turns)
.100 [in->mm]
2.54mm (preload of .100 = 2.54mm or 2.032 turns)
1.25 [mm->in]
0.049212598425196850393700787401575(1 full turn = preload of .049)
1.25 [mm->in]*1.5
0.073818897637795275590551181102362(1.5 turns = preload of .074)
1.25 [mm->in]*2
0.09842519685039370078740157480315(2 full turns preload of .098)
0.3125 [mm->in]
0.012303149606299212598425196850394 (1/4 turn = .0123 preload)
sorry about all the math.....
Sound man you are wright about your feelings most of the time people don,t care about how to fix it or find the cause of the problem.
I better stop why i,am a ahead.
Mike Rogers
i try not to flame... but I dont have any problems putting out the fires coming from those who do...
sometimes I wonder why we cant all just get along.....
If I stressed like some people on here do sometimes...I'd have been dead by 25 form heart failure or an anurism or something medical
Websters definition of Commotion: noisy or turbulent disturbance; agitation; turmoil
