Found this in the oil, what is it?
Old Apr 10, 2005 | 06:55 PM
Nick 02 Z06's Avatar
Default Found this in the oil, what is it?
This came out of my friends 99 FRC during an oil change. Please help us figure out what it is. Yes, the engine is probably toast.
http://community.webshots.com/photo/...19351815PXCraW
Old Apr 10, 2005 | 07:00 PM
firechicken_98's Avatar
It looks like the rollers out of a bearing. I'm not sure though. What ever it is, it's not good.
mikey's Avatar
LS1TECH Sponsor
Needle bearings from rocker arm. Replace the rockers and flush the pan and you will be fine.
Old Apr 10, 2005 | 07:03 PM
LS1x2's Avatar
Formerly 4mulaJoe
Just needle bearing from the roller rockers. Get a new set.
Old Apr 10, 2005 | 07:29 PM
Another_User's Avatar
Man, we keep seeing more and more of those little bastards...
Old Apr 10, 2005 | 09:23 PM
Brains's Avatar
Yup, its happened to a ton of folks. Not a big deal, just replace the broken rocker and prepare to fish a few more of those needle bearings out with the next few oil changes.
Old Apr 10, 2005 | 09:48 PM
That's a relief! I was feeling bad because I just helped him swap in an LS6 intake and thought that maybe I allowed some dirt or sand to get in the intake ports on one of the heads. We were very careful and even vacuumed all the dirt away... What's a good price for a set of stock roller rockers?
Old Apr 10, 2005 | 10:07 PM
1FST99Z's Avatar
naw not your fault nick. heck, i just changed the spark plugs in my car and the next time I turned the motor over it developed a loud tick. ended up being rod bolt had come loose. just coincidence. but yeah find the rocker or rocker arms that are affected and change them out you should be find. it is all part of the modding game.
Old Apr 11, 2005 | 02:26 AM
Lvmyz28's Avatar
has anyone ever had a problem with these needle bearings getting caught in a precarious part of the motor and causing damage? Mine have a little play in them and I"m just waiting for them to fail one day, and I'm a little worried! I'm sure running 400 lbs open seat pressure isn't easy on them.
Old Apr 11, 2005 | 02:32 AM
PREDATOR-Z's Avatar
You can get your set rebuilt with C-clips by SDPC with Harland Sharp parts and machining.
No more spilt bearings.
Old Apr 11, 2005 | 05:24 AM
Z06 Steve's Avatar
thats why the pick up has a screen so all the junk stays in the pan
Old Apr 11, 2005 | 08:53 AM
Camaroholic's Avatar
Just do a search on
found drain plug
in the Internal engine section, and you'll see how common this is. I knew before even clicking on the title for this post...
Old Apr 13, 2005 | 12:04 AM
XuhQshinR's Avatar
http://www.gmtechlink.com/images/iss.../TLNov02e.html
GM TSB: 02-06-01-029
Needle Bearings Found in Oil Pan (Replace Rocker Arms); Specified vehicles 1998-2003 with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, G, S, U -- RPOs LR4, LM7, LS1, LS6, LQ4, LQ9)
Old Apr 15, 2005 | 06:50 PM
Thanks for the advice! You guys were all right on the money. Went over to his house last night, popped both valve covers and found the bad rocker on the passenger side. Bearing retainer was off and sitting in the head. A bunch more needle bearings were also scattered around the top of the head. Used a magnet and got them all out. Dumped some cheap dino oil in both heads and let it run out. Replaced the roller rockers with a set he got for a hundred dollars with 2K miles on them. Fished a magnet around in the pan and found one more needle bearing and replaced the oil and filter. Fired the car up and it seems to be running great. Again, thanks.
Nick
Old Apr 15, 2005 | 06:54 PM
00Z28 Camaro's Avatar
That thing is scary lookin , How many miles do you have nick ?
Old Apr 15, 2005 | 10:07 PM
The 99 FRC Vette with the broken rocker has close to 90,000 miles...... My car has 8,600 miles. I know, I need to drive it more, I just haven't had the time.
