Starting With Stock 6.0 Heads......
Old Apr 11, 2005 | 05:32 PM
IMD's Avatar
IMD
Default Starting With Stock 6.0 Heads......
how trick can i get them hooked up, for $1000?
Old Apr 11, 2005 | 06:33 PM
slyws6's Avatar
Send them to me and I'll take care of them.
-Sly
Old Apr 11, 2005 | 07:58 PM
Bryan@LME's Avatar
LS1TECH Sponsor
We can help you out. You need a nice valve job, econo port and a set of springs. 1000 will get it done.
Give me a call and I can give you all the details. What part of TX are you from?
Thank you,
Bryan neelen
LME
713-849-4505
Old Apr 11, 2005 | 09:19 PM
SiL3NtXWS6's Avatar
I 2nd the vote for LME. Bryan has hooked me up several times now and is currently working on a nice project for me.
Old Apr 11, 2005 | 10:06 PM
slyws6's Avatar
I would also recommend milling them since they are going to have larger combustion chambers, that is depending on how you plan to use them.
-Sly
Old Apr 12, 2005 | 09:53 AM
IMD's Avatar
IMD
Thank you,
Bryan neelen
LME
713-849-4505
im in austin, i dont want the heads milled, i want to lower the compression in anticipation of forced induction. however, i would like to see 375+ to the wheels with heads/cam even at 9:1, before the turbo, because i may be driving it for a while before the FI goes on.
Old Apr 12, 2005 | 10:26 PM
Bryan@LME's Avatar
LS1TECH Sponsor
Sounds like a plan. If you get a chance, give me a call and I can give you any details you need to know.
Bryan
LME
713-849-4505
