MS3: 343 rwhp, 12.2@111. What's going on?
#41
Originally Posted by gollum
This is very simple people. It looks to me like a "classic case" of being over cammed for his set up.
#42
I just realized I might want to give a little bit of missing info that might, you never know, matter.
My 02's were fried recently. I don't know what did it, but I can imagine driving around untuned for a few days, and to the shop, could have been a factor. It ended up running sooo rich, probaby stuck in open loop. I replaced the O2's with a pair of C5 rear O2's (autozone #13111) and the problem went away. Is there any chance at all they could have been bad (but not totally shot) when they did the tune and it threw something off that they were unaware of? They got really bad several weeks after I had it tuned...
#43
Originally Posted by blkZ28spt
Think so? Explain to me how having a cam too large for my gears/converter causes it to dyno at 343 rwhp.
For your set up with 3.23, torque convertor, and headers you would get quicker ET with cam under 220@.050. Shift at 6000 rpm and keep your power band under 6200.
#44
Under 220 duration? I find that hard to believe. Not only that, I asked to explain the rwhp. My combo doesn't have jack squat to do with the dyno output. Actually, if I had a higher stall converter and steeper gears to more accurately match my powerband it would dyno even LOWER.
#46
Originally Posted by ArcticFormula
I don't have experience looking at dynographs but doesn't the torque seem to fall to sharply after peak or is that normal given his combo?
#47
yea i ran the same setup bf afr 205's and dynoed at 369 rwhp. Somethings not workin together with the parts ya got one there, or you got a messed up tune (had that happen once). go with the ls6 intake, bigger throttle body etc. and retune.
#48
Okay, figured I should bring this thread back to life and update anyone interested on my situation. Link to new post:
https://ls1tech.com/forums/dynamometer-results-comparisons/333297-ms3-cam-only-sae-396-rwhp-371-rwtq-unlocked-4000-stall.html
I am no longer making 343 corrected rwhp. I am now making 396 SAE rwhp and 371 rwtq. Cam only through unlocked SSF4000.
All I did was add an LS6 intake and SLP underdrive pulley, with retune. That intake must have choked the ever loving crap out of the cam.
#50
Originally Posted by cyphur_traq
dear god....this is a great testament to the powers of the LS6 intake
congrats man!!
congrats man!!
So, if you plan to cam your car get an LS6 intake manifold first!!!!!!!
