Mysterious Oil Leak
I got under there and have no idea where it's coming from. It's about in line with the passenger side foglight and about a foot and a half back from the front of the car. Anyone have any idea where this can be coming from? I really hate leaking on the floor of the brand new garage and I can't believe a car with only 50k miles is already doing this. Any help is appreciated. Thanks!
IS it oil?
brad
Yep , mine has no odor either . I would drain the reservoir and put in a can of stop leak . I got a can , I just need to go out and do it !
Yeah you can see the line on the back right side of the reservoir . Its got a clamp on it . remove the clamp and walk the hose off . Its gonna drain quickly so have a funnel with a long tube on the end of it going to a drain pan . A tranny fluid funnel is perfect for this . Put the hose back on after draining then fill it up with the stop leak .
The bottle says to pour the entire contents in the reservoir . Its got PS fluid in it too , plus conditioners and **** for the seals . I would check it after I did the procedure and add PS fluid if it needed some . It is also supposed to help the PS system run cooler . We all know that the PS systems in these cars like to run hot and boil out the top of the reservoir on occasion . And yes , check real good around where the PS lines connect to the rack . Mine is leaking around the seal in the boot . I might have to replace the rack on mine .
