Highest compression on pump gas?
#81
Nitrous does create a ****-load of cylinder pressure... after the spark. There's no difference pre-spark. Nitrous does not pack itself in the cylinder along with all of the air that would have gone in otherwise, it takes some of that air's place in the cylinder. There's no force squeezing them in together like i think you're saying. You can burn more fuel with it because it has more oxygen than regular old air. You're packing the same volume of gas in the compression stroke, but with N2O the same volume has a much bigger punch because of the building blocks of power (to make more power, burn more fuel. N2O allows you to burn more fuel due to the higher O2 content).
cylinder pressure.
Now I know I'm talking to a novice.
You just contradicted yourself. You need to add more fuel to compliment
the oxygen density...so guess what? YOu have a higher effective compression
if there's extra fuel!
#82
ok **** face.... this is what we are saying "yes we are running 11.5+ CR and 200+ shot with a stand alone with 100+ oct. in it."
now go back and suck on your mid 12's thumb.
why you sit there and tell us we are wrong with many people hitting 9's on street cars blows my mind... obviously if we are doing something wrong we dont give a **** because we are going fast.
#84
**** face, what is your resulting Dynamic Compression?!
How many times have I asked for cam specs?
Call me so I can record your pathetic explanation for the world to hear.
I'd like to hear you sputter your way through a tech conversation with me.
UNDERSTAND what you're being asked. "Some" of you guys are thinking
in this little box and can't grasp what I'm asking you.
Then you bitch about not lowering compression with N20, but then you say
you're spraying with 100+ stand alone.
Pretty ignorant to call me **** face when you just proved yourself wrong.
#85
I really don't feel like getting into a bitch fest so I will just point out some of the (not all) the things you want to look at.
Combustion Chamber Design and Efficency
Flame Area
Piston Design
Quench Height
Cooling
Coatings
Evans Coolant and Waterpumps
Proper Camshaft
Correct "Tuning"
No one part is going to make a system like this work out.
There is no safe SCR # that should be run on the street on 93 octane, however a 13.5:1 SCR motor that runs on 93 may not be as streetable as an 11.5:1 SCR motor that runs on 93.
Floyd.
btw
~12.12:1 on a 346 CID LS1 on 93
Flame Area
Piston Design
Quench Height
Cooling
Coatings
Proper Camshaft
Correct "Tuning"
Floyd.
btw
#86
Originally Posted by Adrenaline_Z
I'm not going to blow a head gasket.
I think some people are mistaking my reply to say:
"reduce compression to run any amount of nitrous"
#87
You lost my respect at ,
Every link posted, even the one TY_TY posted states that nitrous increases
cylinder pressure.
cylinder pressure.
#88
I'm curious to know why this guy is hell bent on thinking dropping compression and advancing timing is better for making power while using pump gas. I'm sorry, but that is just a crutch; you are igniting the fuel/air mixture early to prevent any possible "damaging" preignition from occuring by firing the cylinder off when it's at top dead center and expecting this to yield more power? You get far more power by increasing the compression, than you ever would advancing spark timing. SBC, LS1 whatever, if maximum power on pump gas is your goal, you will want to run MORE compression, back timing a bit, and minimize piston dwell (the time where detonation has the largest likelihood of occuring). The "problem" with this, is that you need to have an accurate and precision tune which is asking too much from most people. Floyd has listed the major factors for making a high compression pump gas motor. By making an efficient motor which fills the cylinder fast, ignites the fuel air with no obstructions like domes, and bleeds off pressure as fast as possible after ignition, you can bring the conditions within the cylinder as close to ideal as possible for complete timed, combustion.
#89
Link:
http://www.noswizard.com/technical.php
This is why you gap your plugs tighter when you spray...because there is
pressure increase BEFORE ignition and AFTER ignition.
However it is easy to understand that as the pre-combustion chamber pressures rise due to higher volumes of inlet charge, the spark strength required to jump a fixed plug gap is also going to rise"
#91
the pressure increase before ignition is negligible compared to the pressure increase after ignition. the evolution of CO2 gas from the combustion reaction is what creates the most pressure in the cylinder; that's what can blow weak head gaskets, break cranks, etc. if it's not bled off properly. Remember kinetic energy? Once the spark ignites, and the fuel air explodes, the energy of the explosion has already been put on the piston. getting rid of that gas as fast as possible can reduce stress on the moving parts. It's pretty simple concepts here. To run high compression on pump gas, you need to efficiently move air in and out of the engine, with minimum time spent at TDC. Will a 13:1 compression motor with domed pistons and a long *** rod make more power than a 13:1 matched rod, pump gas motor? Yes, but will it be more efficient? Not a chance in hell, and when talking about street motors, a pump gas engine is all that matters. the Long rod 13:1 domed engine will be FAR more octane sensative than the 13:1 pump gas motor as a result of increased inefficiency.
#92
Timing is advanced to give the charge time to expand and place the peak
of the combustion event just as the piston reaches it's most effective crank
angle.
Early timing starts the combustion process as the piston moves toward TDC
and as the charge combusts and expands, it pushes the piston down creating
force. If the timing is placed correctly, the punch of the combustion should
occur before (near) the crank angle that transfers the most linear force to
torque at the crank arm.
the charge energy within 2 degrees of best force?
agree that it's not the best method, or do you like to contradict yourself as well?
#93
of 300 PSI is negligible compared to 1200+ PSI of combustion force?
I guess that's why they call one the compression stroke, and the other a power stroke?
most of the compression and power stroke? Would you like the exhaust valve to open much sooner on the power stroke to bleed off the combustion force?
What are you saying here?
LS1 Tech buddies that are wrong?
You are not making any technical sense at all.
GMCTRuck,
I'll go away when you prove to me and everyone else that gapping your plugs
tighter for nitrous is a bad idea because the cylinder pressure is the same.
In fact, I'll make you all a deal...
If you , or anyone can prove that cylinder pressure doesn't increase before
spark with nitrous, or that gapping the plugs tighter has nothing to do with
increased cylinder pressure from nitrous injection, then I will leave.
Otherwise, all the bench racers can leave? Deal?
What does it take for people to admit they're wrong? I've backed up all my
posts and explained my reasons.
Wait...nobody likes a newb without an LS1.
For the gentleman that said I was being too harsh (Redline2K), I am sincerely sorry.
I get really worked up when it comes to cars and engine tech. Let it be known
that I didn't initiate the hostility...however I'm not any better for prolonging it.
#94
I have no idea what you just stated, but in any case it doesn't make sense.
of the combustion event just at the piston reaches it's most effective crank
angle.
angle.
force. If the timing is placed correctly, the punch of the combust should
Do you thinking adding half point of compression is more effective than placing
Exactly. That's why people take the easy way out. Therefore, you now
#95
Idiot quote of the year:
Are you telling me your spark lead is 0 degrees?
YOu think that starting ignition at 0 degrees TDC makes the most power?
OH MY GOD!
The rest of your post just falls on it's face
Uhh ok, so instead of letting the weaker compression force (force of the piston compressing the fuel air mixture), you are going to ignite the fuel air mixture before TDC for what?
OH MY GOD!
#96
Posted by 5-7
My friend, you need to go back to basics....like 1 + 1.
Seriously.
P.S. By any chance, is your name Terry Vance? Maybe a close relation?
and 90* (which is the angle the piston is a TDC in a SBC, LS1)
Seriously.
#97
Gee, I had no idea? Who would have thought a pre-ignited cylinder pressure
Bled properly? Correct me if I'm wrong, but both valves are fully closed for
Whew! Look out Pat Musi. Let's leave that one alone.
THis is funny. Did you just sign up under a different name to defend your
#98
Posted by 5-7
Seriously.
Seriously.
#99
OH MY GOD!
OH MY GOD!
#100
[Adrenaline_Z]Idiot of the year. Has 13 second garbage, rigged together by a ******* monkey, doesn't get physics or engineering.
File photo attached this is what happened the last time this monkey brained dipshit tried to comprehend basic science. Hate to stoop to this level, but idiocy of the magnitude this ******** exudes needs to be insulted.
