FM15 with ported heads
Old Apr 13, 2005 | 07:18 PM
LS1Maniac's Avatar
Default FM15 with ported heads
I got my car dynotuned today. Last time I dynoed it put down 399 RWHP and 380 RWTQ on the Superflow dyno. That was with the FM15 (Ron Jeremey) cam.
Since then I had my stock heads ported and polished by Force Fed High Performance and I installed an ASP pulley. With these modifications my car put down:
426rwhp and 394rwtq on the Superflow dyno
Dynojet correction factor was 2.6% which would make the numbers 437rwhp and 404rwtq on a dynojet.
This is with stock size valves. The only additional modification was the change from TSP true duals to a custom 3" mandrel bent system that goes under the axle. This would probably hurt more than help the hp in comparison though.
I am extremely happy with these new numbers and I'm amazed at how much hp can be picked up simply by porting the stock heads. Two thumbs way up for FFHP, they did an awesome job on my heads.
I'll post the dyno graph and flow sheet for the heads once I get them scanned.
Old Apr 13, 2005 | 08:03 PM
TJ's Avatar
TJ
less than 20hp and only 5pd ft with a ported head?
id hope you picked up power under the curve.
Old Apr 13, 2005 | 08:12 PM
LS1Maniac's Avatar
It was a gain of 27 rwhp and 14 rwtq over the stock heads. For just porting the stock heads and using stock valves I'd say it was well worth the investment.
Old Apr 13, 2005 | 09:13 PM
TJ's Avatar
TJ
your inital post has been edited.
your hp #'s have been changed.
from the 1st set of #'s you posted, there was a 18hbp and 5pd ft difference.
could have been you posted the wrong #'s to begin with.
now that you edited the post, i look like i cant do math.
Old Apr 13, 2005 | 10:02 PM
LS1Maniac's Avatar
Yeah sorry about that, I was trying to make posts on 3 boards at once and got my numbers screwed up. I'm just putting the Superflow numbers up there. I'll get the graph up asap. I've got the cam-only graph in the dyno section if you wanna see it.
Old Apr 13, 2005 | 10:05 PM
gomer's Avatar
I'd like for you to post the graph so I can see if it falls off after 6400rpm like mine does, it peaks and then it's gone
Old Apr 13, 2005 | 10:10 PM
Bo White's Avatar
Are they stock size valves or the actual production valves? Good #s either way.
Old Apr 13, 2005 | 10:19 PM
Fade2blk500's Avatar
Good #'s for stock valves
LS1Maniac's Avatar
They are stock size Manley Stainless Steel Valves. They're a lot stronger than the production valves.
Gomer, it peaks right at 6500 but it doesn't fall on it's face after that with the ported heads like it did with the stock heads. It actually only looses 5-10hp from 6500 to 6900. The stock heads just don't flow enough to carry on the power band after 6400. I hope to get the graph soon, I'm just waiting on the shop to e-mail me the pic of the graph .
Old Apr 13, 2005 | 10:48 PM
gomer's Avatar
I'll post up my cam only and heads + cam graphs tomorrow. Mine dies quick for some reason. It made the numbers in the sig with ported heads thru the 12 bolt and I have a thread in the dyno section with what it did on stock heads. Did you get a cam card with your F15? If so, what was the actual ICL on your cam?
Old Apr 14, 2005 | 10:11 AM
LS1Maniac's Avatar
Here's the graphs I promised!
This is the overlay of my bolt-ons graph and my cam-only graph:
And here's the one with my new exhaust, pulley, and ported stock heads:
