No power after cam install
The car had to be jump started the last time I drove it (1 month ago), so Im thinking its the batter??
Help me fast
LS1tech Seems like you will need charge circuit testing if the battery continues to drain, or you have a partial short in the electrical system.
If you have access to an ammeter, you can run it in series with the fuse
panel fuses to find out if any circuits are drawing high current.
Throw on a set of booster cables and try your luck in any case.
I'd start by getting under the car to make sure all the charge wires are in tact(alt and starter wires)Good luck
