How much power
Old Apr 16, 2005 | 01:09 AM
Formula-T/A's Avatar
Default How much power
I have a a4 Trans Am with all the free mods,long tubes,lid,1s6 intake,Thunder racing reverse split cam 230/224 .575/.563 111,6.0 truck heads with dual spring kitt. About how much rwhp should it make after tunning?
Old Apr 16, 2005 | 11:19 AM
prostock_bigblock's Avatar
no more than 390 hp ................
Old Apr 16, 2005 | 03:42 PM
Thanks prostock. I want 400 but close enough.
Old Apr 16, 2005 | 03:44 PM
DEEZ98Z's Avatar
If you don't mind me asking.... why did you put on 6.0 heads on?
Old Apr 16, 2005 | 04:36 PM
777's Avatar
777
they lower your compression...i would say no more than 375rwhp...but it depends on what you did with those heads...if they are stock you may not even have 375...you have to remember you are an automatic and they dyno considerably lower...the track numbers are what matter anyhow...
Old Apr 17, 2005 | 03:19 PM
The reason for the 6.0 heads is I plan on a sts turbo or a d1 procharger when I can afford it. I have 100 dry shot but Im tired of refilling it.
Old Apr 17, 2005 | 07:29 PM
JEB99TA's Avatar
Here's what my A4 makes with the converter unlocked (in my sig).
Old Apr 17, 2005 | 08:02 PM
Getav8's Avatar
Mine is a stick but with the TR 237/230 .599/.575 112 lsa cam only and about what bolt ons you have I did 410 to the wheels. Oh yeah I also have home ported and polished MAF and TB
Old Apr 18, 2005 | 12:50 PM
nostyta's Avatar
Just wanted to say waz up & if you go with the sts setup your going to lose that kick *** exhaust sound you have. Hope you get your car striaghtened out , good luck.
Old Apr 18, 2005 | 10:24 PM
Waz up nasty, I just started on mine the other day and my back is killing me. I got the heads off,now I gotta clean all that **** up Hows your the car doing? Man I love the silver and red .
Old Apr 19, 2005 | 08:22 PM
nostyta's Avatar
My car is doing pretty good,I have a post on here with dyno #s, most everyone thinks the #s are low for my setup so I,m planning on changing some stuff, alot of stuff . I seen Keffer today and he told my you had started changing your heads, good luck with everything keep me posted. . Need to post some pics of your car on here 1 of the sharpest T/A s I,ve seen.
Old Apr 21, 2005 | 04:11 PM
madnola's Avatar
I would stay away from the 230/224 cam if you're going forced induction. I don't think the overlap would be FI friendly. Great cam, I have one myself. I am putting down 403rwhp cam only in my Z06 with bolt-ons. Just my opinion.
Old Apr 21, 2005 | 04:48 PM
SiL3NtXWS6's Avatar
The cam you listed isn't a good F/I cam.. too much overlap on a 111lsa.
Old Apr 23, 2005 | 11:48 PM
Thank for the info guys, I hurt my arm at work so my buddy put the car back together for me wensday and it feels great . Thats about all the power I wanted with out getting crazy with it. It wheel hops very,very bad even at a 30mph kick , but at 60 it pulls alot better than I expected.So I guess Ill keep the dry shot since I wont have to use it that much around here. Oh yeah thanks for your help Hucky .
Old Apr 23, 2005 | 11:54 PM
Thanks man,Ill try and get some pics,but Im a lazy basterd . If you see keffer tell him I said hey. Good luck with your mods.
