can i spray on the t rex
IMHO not true. The biggest thing about a nitrous cam is the exhaust valve opening point. Nitrous makes everything burn quicker. Because of the quicker burn you need to open the exhaust sooner to properly scavenge the exhaust since the 'burn' is over. Delaying the exhaust opening point will just reduce the ability of the exhaust to get out of the motor which isn't necessarily the case with a NA motor or one running some other form of fuel such as alcohol or nitromethane (which both burn much slower than gasoline or especially gasoline and nitrous oxide).
Overlap is only going to kill off lowend until the motor gets enough velocity going in the intake and exhaust tracts to make it work. IMHO the overlap that makes the best horsepower NA (which is what pulls the most fresh intake charge in the motor) will work just as well with N2O. Think about it: If the overlap is working to pull more air and fuel into the motor just adding a slug of nitrous oxide to the mix is just icing on the cake. The main requirement of the nitrous is that you need to get it out faster because of the quicker burn time.
BTW, we just had a customer run 9.95 with our 230/224 reverse split cam and a 100 horse TNT kit on a stock bottom end. The point of that is that unless you are spraying an ungodly amount of nitrous the cam really isn't that big of a deal.
Bottom line is that the TRex loves the spray.
As I stated earlier in a race engine whatever amount of overlap you find that works best for your particular combination should be fine for the nitrous.
