Rough idle with turbo cam???
I just recently threw a rod and am looking to build a LS2 402 T76 single turbo set up but I love the sound of my Magic Stick 3 (237/242 603/609 113LSA) . Im assuming this cam would not make for a very good cam in a turbo set up.
I am looking for a cam that works well in a turbo setup with a rough idle (Im not to much into the "sleeper" thing). I just want it to be some what streetable as the car is mainly a weekend car and not a daily driver.
From my limited knowledge I don't think that will happen for two reasons. The first is that you want a high LSA with less overlap so you don't bleed off boost, the other is that the turbo acts as a muffler and *most* turbocharged cars aren't going to have quite the same exhaust note as the NA cars. You will also likely be running lower compression.
MS3 does sound nice, doesn't it?
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
The nice thing about boost is that it doesn't need a long intake duration, but likes a long exhaust duration. The unfortunate bit is that the exhaust event is right before the intake event so it mandates a wider LSA to some extent. You'll have a good lope on a 224/232 on a 113 or 114 and it'll still be good for your forced induction application.
Call up George at Turbo Tech and see what he recommends.
