Help from those with 918 springs
Old Jan 11, 2003 | 09:33 PM
Hoodshaker's Avatar
Default Help from those with 918 springs
I bought some springs from someone that were supposed to be comp 918s. When they arrived there was a nice little note stating that he was not sure that they are what he advertised them to be. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> There are no identifying marks on the springs, although they do have the residue of a verticle stripe which looks red-ish (like surface rust) I know the only safe thing to do is to have the seat pressure tested, but does anyone know if I can tell by looking at them? Does the blue stripe wear off and look like I described above? Help
Old Jan 11, 2003 | 09:57 PM
I8COBRA's Avatar
Default Re: Help from those with 918 springs
I'd get myself a new set of springs and not chance it. Springs are something you dont want to buy used, you dont know if they have 500 or 50,000 miles on them.
Old Jan 11, 2003 | 10:29 PM
98TAauto's Avatar
i may be wrong but i think they are honeycomb shaped as where the stock springs are mostly the same from top to bottom. But like said above, i wouldnt risk it!!! Get the new 918s with the blue stripe on the box
Old Jan 12, 2003 | 12:04 AM
felton316's Avatar
They should be bee-hive shaped (smaller on top, bigger on the bottom) and the newer batches have a vertical blue stripe.
