Double Timing Chain
Old Apr 22, 2005 | 07:26 AM
TA BOY's Avatar
Default Double Timing Chain
What Kind Of Problem Does The Double Timing Chain Causes?
Old Apr 22, 2005 | 07:43 AM
JoeyGC5's Avatar
18k miles on a rollmaster dual with no problems.
Old Apr 22, 2005 | 09:15 AM
SiL3NtXWS6's Avatar
i also have a rollermaster double and no problems.
Old Apr 22, 2005 | 09:26 AM
FroDaddy's Avatar
trouble with these is few and far between from what I've read here. I haven't had any trouble with mine, but I've only put 1500 hard miles on it.
Old Apr 22, 2005 | 09:33 AM
777's Avatar
777
they cause you to not worry about your engine as much
Old Apr 22, 2005 | 04:46 PM
T/A rocker's Avatar
Only trouble I know of, is IF you have an ASP crank pulley (and this only applies to the older ones) you will have to get the pully snub machined about .100" for it to seat all the way. Or something like that
Old Apr 22, 2005 | 05:26 PM
pdd's Avatar
pdd
yup. i had an asp and it didnt fit. i got a super damper and it fits with the dual roller
