formula for valve lift
Old Apr 22, 2005 | 02:30 PM
Stryker's Avatar
Default formula for valve lift
i need to find a formula for figuring out valve lift with 1.6 rockers. any input will be great. thanks.
Old Apr 22, 2005 | 02:52 PM
Taspeed's Avatar
I am guessing that this is an ls1? You need to take the current lift of your cam and divide that lift # by 1.71. Then multiply that product, which should be the actual lift height of the cam, by 1.60. That will give you the new lift.
Old Apr 22, 2005 | 02:54 PM
Stryker's Avatar
its for an lt1 car.. is that the same?
Old Apr 22, 2005 | 02:58 PM
SMOKINV8's Avatar
By that formula, you'd just divide your cam lift by 1.5, then multiply that product by 1.6.
Old Apr 22, 2005 | 02:59 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Valve Lift = Cam Lobe Lift X Rocker Ratio
Therefore, if the lobe lift is .300 and the rocker ratio is 1.6, the Valve lift is theoritically .300" X 1.6 = .480"
Old Apr 22, 2005 | 03:02 PM
Stryker's Avatar
well for once that was simpler than i anticipated thanks guys..
