Spun Cam Bearing ?
Yes but you would not hear it for long... I would go back and like luv said, check the belt with some wd40. If you have low oil pressure, and odd sounds, you are on the right track to a bearing problem. I suggest you find the problem(s) before its too late.
What did you install, what other problems are you noticing?
Rob
I think its the pulley because I originally put it back on wrong, so we had to take it off and re-install it. The noise hasnt went away, and its the only "odd" sound that I can hear. No weird clinking or clanking from the engine itself. I also haven't really driven the car more than 10miles since the swap, and I haven't taken it abouve 3k rpm's because of the low pressure (it now starts out at 40psi, and slowly drops to 20psi while driving (at low rpm's, but it should still be way higher).
That is why I think it may be the o-ring. At start the pressure is fine, but once the oil starts cycling the oil pump looses vacuum because of the possible o-ring??
I installed a brand new crate motor in my 79Z, except I replaced the cam and valvesprings. Got 'er started up, she squeaked pretty bad. I pulled the belts and ran it briefly with no waterpump and no alternator. Still squeaked.
Pulled the motor back out and apart and went through everything (pulled crank, cam, etc). Found: nothing. Everything looked perfect and new. Put it all back together. No more squeaking.
Sometimes you just never find your gremlins. Glad yours was the belt.
Now, the oil pressure stayed at 40psi while I just took it for a 15min drive and back, it dropped to 20psi at idle, but it went right back up as I drove it around. I also did a little pull to 4.5k and the pressure was at around 45-50psi.
I still think it ~should~ be higher, but I dunno...
