HELP Installing spring seats
Old Apr 23, 2005 | 04:50 PM
Jeffs99SS's Avatar
Default HELP Installing spring seats
I'm wrapping up my cam install, and I'm in the middle of installing the springs. I have Manley dual springs, and they are being installed in STOCK heads.
My question is: The seats also came with a set of 16 very thin washers of the same diameter of the spring seat. I assume these are included to change the installed height of the spring? Should I install these under the new springs?
Thanks in advance
Jeff
Old Apr 24, 2005 | 08:20 AM
ROGERSPERF.'s Avatar
No you need to check your install height first to determine if you will need the extra shims to get the spring seat pressure wright.
