what kind of oil?
Old Apr 24, 2005 | 03:08 PM
akZ28's Avatar
Default what kind of oil?
I live in Texas where it can be over 100 degrees in the summer. I was wondering what oil yall would reccommend. I have heard good things about Mobil 1 10W-30 but i also heard synthetic does not do good in hot weather.
Old Apr 24, 2005 | 03:19 PM
santino04's Avatar
Most people including myself will recommend a 0w30 0w40. You should be fine with either. Also you can search some of patmans posts hes the oil expert on LS1TECH. Good Luck
Old Apr 24, 2005 | 07:59 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
Run Mobil 1 and sleep well.
Old Apr 24, 2005 | 08:56 PM
01_SuperSlow's Avatar
Mobil 1 0W-40
Old Apr 24, 2005 | 09:28 PM
glennhl's Avatar
I live in Phoenix and it gets really hot, so I will not run any 30 weight oils. I run Mobil 1 0W-40 in my 01 and Mobil 1 15W-50 in my 94.
Old Apr 24, 2005 | 11:36 PM
RedZoutlaw's Avatar
Not 100% but doesn't NASCAR use full synthetic oil? Those engines get quite a bit hotter...plus I hope synthetic isnt bad in really hot weather.
Old Apr 25, 2005 | 04:35 AM
Patman's Avatar
You heard wrong. Why would a superior oil be worse in the summer? Synthetics perform better in extreme heat and extreme cold compared to conventional oil.
Old Apr 25, 2005 | 05:07 AM
JMBLOWNWS6's Avatar
I run 5 1/2 10-30w and 1 quart of 0-40w and use 6 1/2 quarts in the system. Thats with the K&N oil filter that flows really well
