oil in intake even with ASM catch can
What would cause this.
PCV in new....working fine. I am alos drawing from the plate below the intake manifold...I purchased the LS6 cover.
Thanks for the suggestions..
Tom
Is it coming in front of the throttle body from the fresh air line .
It might be the baffel in the Katech valve cover is not doing the job .
I think I get some in the front also from the fresh air line.
I have the morosso evac system if you want to try it Tom ,It might be good for a couple of hp .
Its new and I have it setting here ,let me know
I'll bet if you still have the front hose from the valve cover to the front of the
TB u'll still have oil even with the evac system
JWSR
Its definately coming from the PCV...
Keep the ideas and suggestions coming.
It catches the oil vapors that do not condensate in the can.
Not beautiful but effective.
In all i would say 97% of the oil that used to make it to the intake is now collected.
Tom
