Help PLEASE!!
So like 2 weeks ago i got a cam swap and a full dyno tune. All of a sudden this week after i drive the car for any amount of time and turn the car off, then try to start it back up nothing happens.... Like when i press the clutch in and turn the key it doesnt even click or anything... It seems like the car doesnt know the clutch is engaged... But the weird part about it is... after u let the car sit for about 30 mins then try to start it again it will fire right up... no problems at all.... Does ANYBODY have any clue whats going on here?
Originally Posted by 01Generalee
you could probably do it your self. the starter is like 2 bolts I think. Just get a new one at autozone and if that dont fix it you can take it back.
I presume the battery was disconnected recently. Did you check your battery cables? They could have a loose connection. Also, cables can crack, or be corroded, inside the insulation. You may still have power to your accessories with a failing cable, but not enough juice to kick the starter. Let us know...
the battery is fine... double checked the cables its an optima battery.... car has 42k miles on it... stock manifolds and cats.... but b4 the tune i shot a code for my passenger side catalyic converter....
Originally Posted by Prophecy
Whats the VATS system? english plz.
but make sure to bitch at the counter guy that they sold you a bad part
I have been in the reapir business for years and this is the mentality that causes us the most problems,YES it could be the starter but without knowing for sure make it the parts suppliers problem
