Timing Chain Question
Old Apr 26, 2005 | 12:37 PM
mochiles's Avatar
Default Timing Chain Question
I have read that the SLP double roller is just an over priced rollmaster double. Is there any validity to this? Imm looking to save money where I can with my cam, install so if this is the case I will get the rollmaster rather than the SLP. Thanks for any info.
Drew
Old Apr 26, 2005 | 12:52 PM
Cal's Avatar
Cal
Since you don't want to waste money, you should forget about the double roller chain, it's overkill. Get a LS2 chain or a JWIS single roller, whichever is cheapest.
Old Apr 26, 2005 | 01:23 PM
GuitsBoy's Avatar
Since you don't want to waste money, you should forget about SLP altogather. Cal's right, look into an LS2 chain for a hair over 28 bucks and reuse your stock sprockets.
Old Apr 26, 2005 | 03:19 PM
mochiles's Avatar
Well Im not trying to squeeze every penny I can, I was just wondering if the SLP and Rollmaster were the same things. Is the LS2 just as good?
Thanks
Drew
Old Apr 26, 2005 | 03:54 PM
Cal's Avatar
Cal
I belive there was a thread a while back that indicated most of the double roller chains are made by the same company. I think an LS2 chain would be even better than a double roller; less rotating mass and it will never cause interferance with an under drive pulley. BTW, these pulleys are an excellent mod that works and has no side effects if you don't already have one. How do you like the aluminum flywheel?
Old Apr 26, 2005 | 04:08 PM
Jeffs99SS's Avatar
I decided to go with the LS2. No hassles with changing crank gears, spacing out oil pump, or getting the pickup tube back into the pump. Plus the price is right.
Old Apr 26, 2005 | 04:16 PM
mochiles's Avatar
Thanks that clears things up alot. I think I will look into the LS2 chain. Part #?
Cal, I like the aluminum flywheel it revs up like a ****. Its not bad at all when shifting. I had heard that it can kill revs when shifting but no probs here.
Drew
Old Apr 26, 2005 | 08:38 PM
TDH02's Avatar
Drew
Give this guy a call. He will hook you up.
Kris Jones
Scoggin-Dickey Parts Center
kjones@sdpc2000.com
1-800-456-0211 ext-353
Old Apr 26, 2005 | 09:59 PM
Bigrob339's Avatar
Is there anyway to get the part # because i will soon be doing my cam swap and was also looken at a double rollermaster chain but wasnt looken forward to swapping oil pump and decided against it my car only has 22k. Will the ls2 chain hold up to a FM13 cam?
thx rob
Old Apr 27, 2005 | 08:07 AM
GuitsBoy's Avatar
yes, implanning on using the ls2 timing chain with my f-13. Its part number 12586482 and goes for 28.25 on SDPC2000.com IIRC.
Old Apr 27, 2005 | 01:54 PM
d james's Avatar
to get that old chain off and new one on don't you need to remove the oil pump? I've heard some horrible stories with crimped oil pump O rings and such, which makes me want to leave on the old one, but if it can be done without removing all that I'm all for it. From pictures it looks like the oil pump would have to be removed, I just want to make sure before I purchase a LS2 chain?
Old Apr 27, 2005 | 02:41 PM
ledfoot's Avatar
LS2 timing chain P/N is 12586482 - about $25 from GM Parts Direct or Gene at Fred Beans.
Old Apr 27, 2005 | 02:57 PM
GuitsBoy's Avatar
Yes, you need to remove the oil pump. Do it now or do it later...
Old Apr 27, 2005 | 03:55 PM
Cal's Avatar
Cal
It's not that hard to reinstall the oil pump, don't let the horror stories freak you out. As someone else said, "Just go slow and think about what you are doing." Use a new O-ring and lube it up good first. Then just kind of work it in there slow, don't force-fit it.
Old Apr 27, 2005 | 06:31 PM
Bill Bowling's Avatar
I just installed a Rollmaster Chain and LS6 Ported Pump with my cam. It is not that hard to install. Check out LS1howto.com The rollmaster is the same as the SLP.
Bill
Old Apr 27, 2005 | 07:25 PM
blkZ28spt's Avatar
The oil pump and pickup tube O-ring are a PITA, but not that hard. I installed a rollmaster double and new oil pump with my cam swap and it went alright. Just be very carefull with that pickup tube bolt. There is a blurb about that in my cam swap thread. (see sig link)
Old Apr 27, 2005 | 09:09 PM
Bigrob339's Avatar
So wait, if i am to do a LS2 timing chain with my install, do I need to remove the oil pump if i am not going to replace it? Or does it need removed to get the chain around the crank gear?or does the LS2 timing chain part # 12586482 come with a new crank gear that needs to be put on?
thx rob
Old Apr 27, 2005 | 09:11 PM
Cal's Avatar
Cal
LS2 chain works with your existing timing gears. You have to take the pump off because it traps the chain with it's mounting points.
Old Apr 27, 2005 | 09:33 PM
Bigrob339's Avatar
awww god i am retarded, i was thinkin of like a chain with a master link but i just realized and thought about it and well i am dumb lol sry. So any way that LS2 chain will be ok on orig. crank gear?also my car only has 22k will it be fine to leave the oil pump?and is that chain ok for the FM13 cam?
thx rob
