no oil in top of motor with good oil pressure
i have a 2000 Ws6 and im not geting any oil to top of motor. oil pump is fine. i took valve covers off and hooked everything back up and confirmed that there is no oil. so where should i start i know i have to start a tear down, but what to i look for? thanks Frankie
Rockers
Push Rods
Lifters
Anything more and you are tearing down the engine. Try running the engine with the valve covers off. I'm not sure how easy it will be since the packs are mounted on the valve covers, but you might see what is going on. Don't do it too long though.
Push Rods
Lifters
