why smoke?
Old Apr 29, 2005 | 07:48 PM
99f1's Avatar
Default why smoke?
My 99 camaro smokes pretty bad on the decell.....It didnt smoke with the stock exhaust(I didnt notice it).I have a full mac system on it now ,with off road y...........does anyone know why this is,or if I should worry.I realize a little blowbye is common,but this is more than a little.It doesnt smoke at an idle,or if I just cruise through the gears,only under a descent or heavy load,ecspecially on the decell..but a little when I switch gears too.Pleeeeze help...thanx
Old Apr 29, 2005 | 11:06 PM
oange ss's Avatar
maybe a stuck PCV valve
Old Apr 29, 2005 | 11:09 PM
Cal's Avatar
Cal
LS1's all blow oil at light load because their light tension rings flutter in this situation. But it shouldn't smoke under heavy load unless the rings or valve guides are shot. A compression test might give you some clues.
Old Apr 30, 2005 | 09:03 PM
99f1's Avatar
Default leak down
did a leak down...everything is tight,fluttering rings explains it,I didnt realize they perfomed like that.It really doesnt smoke when Im killing it,but more when I let off,thanx for the input....anything for sale your way?
